What angle.....
ronald.collins@valero.com's avatar
What angle.....
974door's avatar
974door
May be a dumb question, but what angle do you put your frame rails at when doing a stock floor body drop?
BioMax's avatar
BioMax
I'm not sure what you are asking.
974door's avatar
974door
Where the frame rails run to the rear, and go up for the notch. In front and behind the axle.
thacru78's avatar
thacru78
The 2 frames im building right nowt I ran them up at 72 degrees....made 2...37 degree cuts. Not sure it really matters. Just a preference in looks...90 is ugly...but if it to layed back then it takes up alot of room and that just that much more bed you have to cut up....just my .02.
BioMax's avatar
BioMax
On any frame clip I will draw out the suspension in full size and run the frame rails so that I can easily build bag mounts to them. The angle of the frame will be different depending on where the bags will be mounted.
974door's avatar
974door
Cool. Thanks for the info. That is the way that I have been doing it, just wanted to make sure it was the right way. Thanks again.
