Mazda Trucks \  MAzda B3000 help
MAzda B3000 help
Mazda Trucks Make Specific
views 227
replies 5
drptndrgn   +1y
   I just picked up a 94 mazda b3000 and cant find much for it or even people with lowered ones..
Its the gay i beams up front do they make a spindle for it or springs?? or is my only option ibeams to lower it??
some one point me in a direction please lol
slammedcivicsi   +1y
I used to have one, I used I beams....but if I did it again, I would just clip the front end to run a spindle, and arm setup. I would probably use something from a Toyota, or Ranger.....but any of the ranger stuff would be compatable.
drptndrgn   +1y
im just wanting to static drop it as a daily nothing crazy im to focused on my gsxr right now to dump  any money into this truck... its a 94 with 86k miles i picked it up at work for a grand and just wanna lower it a few inches
maz duh   +1y
Drop beams will do the trick for a static lowering job in the front and a flip kit out back.  You may also want to look into a new set of raised radius arm mounts and a raised trans x member as well to raise the scrub line up some. A rear c notch kit would probably prove to be a good investment as well, this will help improve the ride in the rear. A good set of lowered shock absorbers would be a nice adition to the package as well, good shocks will really make the ride nice. G'luck with it man.
drptndrgn   +1y
so just found a lowering kit on craigslist... its beams rear leafs and springs... says 95-97 ranger... would it fit my mazda
slammedcivicsi   +1y
yes it should fit your mazda....but you'll still need a flip kit for the leafs. You can easily make one with by cutting out box tube, and gusseting it, and drilling a hole for alignment.
