so i know the toyota rear ends are pretty universal, what about the third members? Are the 79-95 third members all the same and interchangeable?
TwistedMinis
Not really. There are two different axles sizes, 7.5" and 8" which have a different bolt pattern. There are also 1 ton units that have a larger spline count.
obey
how can i tell which is which, guy has a 79 thirdmember i would like to use on my 93 rear end..
achievment_farmer
measure the ring gear, count the splines on the axles and check the third member bolt patterns to each other.
TwistedMinis
You can tell an 8" from a 7.5" differential or housing at a glance. The 8" has (if looking at the pinion flange, or front of housing) a stud that is sightly to the left of 12 O'clock. It also has two longer studs. The 7.5", I believe the highest stud is right at 12 Oclock and has only one long stud.
