Chevy/GMC Trucks \  97-98 chevy ? about the abs .
views 161
replies 5
following 5
tucn1ton   +1y
what is every one doing with the abs block? any pics would be help full.
bigjon   +1y
replacing it with manual brakes new 7in booster and MC.
tucn1ton   +1y
older mc and booster.. thanks for the info..
tre5   +1y
You can run residual pressure valves and a proportioning valve. 2 PSI to discs, 10 PSI to drums, proportioning valve to the rear. You can get all of this from speedway motors. I did it on the 2 door tahoe I am building now. Go look at the thread.
just2ttu   +1y
all i did with my 97 was got a old proportioning valve from a 88-94 c1500 and put that in the main lines.   i used both the stock master and booster from the 97.  truck stoped on a dime!  hope this helps. Grounded 4 Life Kustomz
Kuzierndt23   +1y
I did the same as just2ttu.....works great....factory booster and mc with the proportioning valve....
