help with fuel pump ?????????
hrdcorerocks@yahoo.com's avatar
hrdnissan's avatar
hrdnissan
does neone out there know of a fuel pump i can use in my 97 hardbody inline instead of in the tank cuz i have a fuel cell and i keep haveing problems with the stock one   locking   up   and this is the second one i have put in there so i trying to find one that has the same psi but i can run inline. I i could get some help on this that would be awsome.............
slmmdd97's avatar
slmmdd97
Edited: 6/6/2009 1:22:07 PM by slmmdd97
hey just thought i would hlp out a lil.  I checked summitracing.com and they have in line pumps and they are rated anywhere 22 to 120 psi.  you may want to call them just b sure on specifics. I also checks jegs but summit has more of a selection. hope this hlps.
bdmpastx's avatar
bdmpastx
yeah you can use the Summit ones but you may want an adjustable fuel pressure regulator as well. They work really nicely and you won't get stuck with dimension issues due to the stock fuel pump. you can run a slimmer fuel cell hidden under the bed with the same volume and run an aftermarket pump without issues.
hrdnissan's avatar
hrdnissan
thank you guys thats a big help,cuz it would be nice to run a slimmer fuel cell so I can hide it under the bed
fxCUSTUMZ's avatar
fxCUSTUMZ
I use the Walbro universal fuel pump on mine and did not have to buy anything extra, other than the hose to run to it.  I mounted mine under the truck inline with supply line to the fuel rail.  You dont need another fuel pressure regulator, since the truck already has one.  These should run somewhere between $89-120.  Summit also has there name on one, but its the same fuel pump.  These are all over ebay.   I hope this helps,   Billy
hrdnissan's avatar
hrdnissan
so  i'm looking at buy n this fuel pump from summit ' SUM-G3138 ' it is 85 PSI and 43 gph,so from what the guy on here was saying i wont need a PSI reg becase the nissan has on already on it   ? is this true? will this fuel pump work for me?
fxCUSTUMZ's avatar
fxCUSTUMZ
that fuel pump is the exact same one I have on my truck, but mine says Walbro on it instead of summit.  My truck is a 98, which is the same drivetrain as your 97.  This should work nicely.   I took my tank completely out and added a fuel cell and this pump and did not add any other Pressure regulator.  Mine has been on now for almost 2 years.     Billy
hrdnissan's avatar
hrdnissan
thanks bro for your help i will go on and order it today
