Page 1 of 3
Air Ride Suspensions \  why is my driver side lifting up slower than the rightside...
Air Ride Suspensions Q & A
views 840
replies 21
following 17
VICS22   +1y
VICS22   +1y
I HAD A FRIEND TELL ME IT MAY BE THE GROUND.SOMEBODY HELP...IM RUNNIN FOUR VAVLES TO THE FRONT....
minitrucker6669   +1y
well are you sitting in it? may be extra weight? i know my buddys old truck used to be fast on the right side but if i was in it was slow and usually if we went far he was constantly filling the bags haha
VICS22   +1y
nope...
m2edragger   +1y
kinked airline on the left?
FADE2BLK94   +1y
air leak on that side? may only leak slighty when its above a certain pressure possibly?
supravan   +1y
is the air line the same length on both sides from the valve to the bag? if one is longer that the other 1 side will lift faster than the other side
VICS22   +1y
THANKS I KNOW I DON'T HAVE A KINKED AIRLINE,IM GOING TO CHECK IF THEY ARE THE SAME LENGTH,
VICS22   +1y
WHAT IF THE VAVLES ON THE RIGHT ARE CLOSER TO THE BAGS THAN THE ONES ON THE LEFT,WOULD THAT MATTER..
FADE2BLK94   +1y
---------------------------------------------Originally posted by VICS22WHAT IF THE VAVLES ON THE RIGHT ARE CLOSER TO THE BAGS THAN THE ONES ON THE LEFT,WOULD THAT MATTER..--------------------------------------------- Yes, it can make a difference. I always try to space mine out exactly the same from side to side, but it may never be perfect you may still have one side a split second behind the other.
