Truck Performance \  What would b a good rearend 2 run in a 97 gmc sonoma on the street only?
Truck Performance General Discussions
views 1417
replies 6
following 6
SONOMAONBAGSLAYNDUBS   +1y
 I have a 97 gmc sonoma ext cab that i got a 383 stroker that is bored .30 over an i gotta turbo 400 trans 2 go behind it with a b&m shift kit. im tryin to get a good rearend to go in it with this setup on the street that i want mess up.any help an suggestions would b greatly appreciated.
minitrucker04   +1y
12 bolt, ford 9 inch, i got a built 10 bolt in my s10
what gear would b good 2?
minitrucker04   +1y
i got a 4:10s, but if your going to be driving it every day i would do a 3:73
societyoutkast   +1y
^^what he said a pef set up would be a ford 9 inch with some 373's but i'm sure you could use the common 8.8 out from under a stand and i'm sure there are a tun that are already geared
scotto79   +1y
Edited: 7/7/2009 6:55:08 AM by notlowyet
Use an 8.8 from a 95 and up Explorer, you would just have to probably shorten the axles though.  But you will get a 3.73 and disc brakes at the same time.  If you order new axles for it, Moser or whoever will be able to do the GM bolt pattern instead of the Ford pattern as well.
FCKNLOW   +1y
i went with a TEX 9in with 3:73 good combo!!! i also have a 383 with a turbo 350 tranny (fully built).
