hydrolic setup help
callmecoryx@yahoo.com's avatar
hydrolic setup help
achievment_farmer's avatar
achievment_farmer
i've recently have been thinking of doing a hydrolic setup on my truck, and i don't know much about hydrolics or anything about setting them up.  i was wondering if someone would give me a list of what all i would need to install one and the basics of setting one up and some pics would be appreciated too.
AON-OFFDAHOOK's avatar
AON-OFFDAHOOK
What kind of truck?
achievment_farmer
92 toyota pickup, but its gonna be sfbd also
AON-OFFDAHOOK
A toy would be set up a similar way up front and you can do something similar in the back, or the cylinders right-side-up in the rear with a mount off the bridge/crossmember: http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=387834500&albumId=1264392 Factor a 2 dump setup (kit), 2 pairs of heims, accumulators, and if you're going the Hydroholics.net route, some threaded sleeves will help with with your install and fine tune it. You'll also get some batteries (2-4 depending on speed). You'll also need some small hardware, and welding cable and a quick release ground.   You can also do some more fun/cosmetic items such as hardline, gauges, switch extensions, etc..   I can't think of anything more awesome than a juiced toyota - do it!
achievment_farmer
i've been watchin' and readin' all the hyroholics.net builds and they got me wanting a hydraulics setup.  thanks for the info
achievment_farmer
also, what if someone wanted to buy it piece by piece, could you list what would be needed to do mine? i want to just buy the kit but i will probably end up getting it piece by piece.
