Chevy/GMC Trucks \  66 steering
66 steering
views 279
replies 2
following 2
phatedscustoms   +1y
I've got a 66 chevy that i've swapped out front ball joints, spindles etc... with parts from a 74 chevy donor and need to put the power steering gear box and idler arm on my 66 frame does anyone have any build pics of this process or can point me in the right direction to make sure i get everything aligned where it's supposed to be? mocking it up i beleive i have it pretty close but i just want to be sure.. thanks!
sunkensub   +1y
You need to use the 66 idler arm, to put the later power steering box on the 66 frame you need to buy or make a spacer/adapter plate because the later steering box is bigger. I don't use factory tie rods, imake/ use heimed tie rods when i do the conversions. You can get the adapter plate here: http://reztrucks.com/
phatedscustoms   +1y
thanks a lot for the info
