3500 with a oasis need kinetik help
low95xlt
ok what kind of kinetik is everyone running for there oasis compressors?
erikharbour's avatar
erikharbour
Based on the need of the oasis its roughly 800W give or take so add that with the motor of about 1200-1500W and with no audio you need to support roughly 2100W.  So you have some options based on the room you have to work with...  1 Hc2000 would run it just fine, or if space is an issue 1 HC1400 and then 1 Hc800 or you could even do 2 Hc1200s.  Remember the model numbers equal wattage so make sure you have about 2000W of wattage support and you should be good to go! The Oasis pulls 800 - 1000 at full cycle but assuming that you are not always needing to fill it is more at idle so to speak at that time so not pulling all that power constantly.  Now if you are going to add AUDIO to the mix remember to add up the wattage and make sure you match model number wise and you are supported!
