Air Ride Suspensions \  **HYDROHOLICS - Another New Innovative Product**
Air Ride Suspensions Q & A
views 409
replies 17
following 16
AON-4PumpedCL   +1y
New from Hydroholics REVERSE PORTED BLOCKS. Now you can plumb both of your pumps for a symmetrical look without having to turn your pumps, or change your plumbing. These were designed for the use with pumpheads that can accept an oil pickup (as the pumphead's position is changed). They are aluminum, 3/8 ported and engraved on both sides. $89 each for the reverse block $79 for a standard block, or $37 price addition to any of our 2 pump kits. Standard on left, reverse on rightStandard on top, reverse on bottomStandard on top, reverse on bottom
bendapirate   +1y
I have no idea what these are but they look super high quality!! :LOL:
Xpendable   +1y
^^ Haha i was just about to say the same thing.
AON-OFFDAHOOK   +1y
These blocks are what join the tank/gear & motor together.  The two ports are Pressure (out) and Return (in).  In the past one would have to plumb their pumps exactly the same way which either the pumps or the plumbing is flip-flopped to get it to look right.  No for flip-flopping as now you can have a left side and a right side and have your setup look nice and symmetrical.
YUH8IN96   +1y
thats a pretty good idea, is that wut Tre5 has in the benz???
tre5   +1y
No, I have 2 normal pumps in the benz.
YUH8IN96   +1y
o i jus thought that cuz u got the pumps runnin the same way right next to each other
juicedwagon   +1y
this is an idea i bet so many people have thought of including myself and im glad you guys stepped up and made it happen.  will be good with a whammy tank settup also
k24 rd6   +1y
Edited: 7/22/2009 4:50:06 PM by k24 rd6
Cool I see a recess around the hole. Please tell me that is for an o-ring and real threads.
tre5   +1y
There are 2 recesses. The one in the middle is for the pumphead seal. We use a double o-ring seal for the pump head seal. The other recess is also for an o-ring. Neither of those holes are threaded though.
