Air Ride Suspensions \  hydraulic question
hydraulic question
Air Ride Suspensions Q & A
views 178
replies 6
following 6
homebuilt   +1y
i was wondering if you could run hydros off of a power steering pump or somthing like that.  maybe like a bobcat or loader.  i dont care about the speed, just want up/down.  would it have to be manually actuated?  thanks.
maz duh   +1y
Lenny Gruver had his S10 suspension run off a pump for a snowplow at one point so its deffinitly possible. I'm not sure of the speed but I would guess it wasn't too quick being a single pump. I'm going to speculate that there were more negatives than positives based on the fact that I haven't seen another setup done that way since but I could be wrong on that one, I'm no hydro guru . Hopefully some others chime in 'cuz I'm wondering now. L8
DRGN4DR   +1y
thats how some of the old school hot rods used to do it. they werent being lifted very high tho i dont think. it is possible to do tho.
homebuilt   +1y
thanks for the quick replys.  i figured it wouldent be worth it, cause you dont see it everyday.  i guess you would have to have a large reserve oil tank to lift it high.  if i dont do that i would like to do somthing simple like one pump 5 dump.  thanks again.
tre5   +1y
There are several different forms of pumps used for different applications. But, like you said, it wouldn't be worth the trouble to try and retro something else for use in a car. More than likely it would be a lot bigger and a lot slower. Back in the day not so nice people used to steal pumps from Tommy Lift Gates. They were very similar to what we call a normal pump. Even before that the lowriders started hydraulics on cars by using aircraft hydrauliucs. The aircraft hyros have made a huge comeback. Check out the thread on layitlow.com for some seriously insane aircraft setups.
k24 rd6   +1y
My fab guy was talking about this when we working on  my car. He did a quick estimate that my Honda ps pump could do around 800 lbs of pressure. I think it would work for basic slow up/down.  I like the idea of using the ps pump and hiding the storage tank. In reality it seems like alot of extra plumbing and headaches.
tacomaon24s   +1y
i have found a powersteering pump that puts out 1600 pounds of pressure and is all billet aluminum its about the size of a hydraulic gear inside a normal pump uses an external resivoir and pumps 3.2 gallons  a minute also spoke with the machinst that makes it and have a hydraulic chart from caterpillar that has cylinder diamiters and pressure amount for certain weights basically a cylinder with 1.120 inside bore and a 3/8 id hardline with a pump that puts out 800 psi can lift about 1600 pounds of dead weight per cylinder so a pump that puts out 1600 psi and two 1.120 id cylinders can dead lift a weight of about 6000 pounds with .50 id hardline and it would be fast as hell at 3.2 gallons a minute cosidering a cylinder only uses about a max of 12 ounces of fluid rember this is all in testing right now but thats what i am using for my truck any help is apprecited
