chevy full size help PLEASE
9
96canedcivic
im looking at buying this full size but it used to be a 5 speed and the guy swaped it over to auto and u still have to push the clutch in to start it what do i need to do under the dash or in the column it fix this and if the trans starts jumping rpms when its in over drive this is a sign of what? thanks for all the help fellas
Mater's avatar
Mater
What year is the truck? The o/d sounds like the installer may not have wired in an O/D lock up harness. On an ECM controlled trans the computer tells the torque convertor when to go into lock up and when to unlock. If it is a 700R4 trans then you can buy a lock up harness to convert it.  The clutch pedal is a read to ground circuit. The pedal hits a switch and makes ground. Get a wiring schematic and it will show what wires need to be by passed and what need to be sent to ground.  Hoped this helps
9
96canedcivic
91 thanks for the help and where can i get this harness at
Mater's avatar
Mater
I know both TCI and B&M make one. Both are available through Summitt and Jeg's
9
96canedcivic
ok now here is another problem when the truck is running and u put it in gear it will stall out and if u get it to run it sputters and wants to die and i also need some wiring info i wana put a 98 dash in it the truck is like a 90 what will i need to do to get the gauge cluster to work in this one ?/
9
96canedcivic
anyone?????
fredstinting's avatar
fredstinting
there should be a clutch switch you can bypass to so the clutch get used any more i did this on my 5 speed s-10 thinking i had a bad clutch switch chevy dealer  told me what to do never had to push the clutch to start the truck .
9
96canedcivic
ya i got that fixed had to put in a new gas tank as well and re wiring this thing should be up and running soon anyone do the 98 dash swap if anyone has some tips let me know
