Switchbox and Valve wiring
skinny76
I wired up my valves and switchbox today. The rear works fine but when I went to pop up the front, Air just came shooting out of the dump.  If it was wired wrong why would there even be air going through the fill to the dump??
I have the Fill valves mounted straight to the tank then a T and A dump on one end and air line coming out of the other end. If that helps.
I'm going crazy thinking about this! Thanks for the help!!Kenny
DOWNHERE's avatar
DOWNHERE
Valves are 1 way... U plumb them backwards, they will not hold air.... I did the same thing with my truck... Live and learn!
skinny76
Ok! I'll check tomorrow!  Thanks for the help!
skinny76
Ok, I checked and all the valves are the right way!  Now what?
fredstinting's avatar
fredstinting
i can help you but need to see a pic of the valves installation or better description of how there installed
skinny76
Fixed!! One of the wires came undone.  As soon as I put it back on everything works fine!!
