Switchbox and Valve wiring. Help Please!
skinny76
I wired up my switchbox and valves today. The rear works fine, but when I went to pop up the front, Air just came shooting out of the dump!  Does this mean its wired wrong? If so why is air getting throught the fill valve and going through the dump? The fill should still be closed.
I have the Fill mounted to the tank, then a T fitting ,and a dump on one end and Air line on the other end. If that helps.  Thanks for the help!
MF
Master Fabber
sounds to me like the fill and dump are both energizing at the same time. Unwire the dump valves and see if that stops it . That will tell you if that is whats happening. Good luck JR
fredstinting's avatar
fredstinting
i think your switch box is wired wrong hand a few that would short out different valves in different system had to rebuild the valves to get them to work and replace wire and switches in a new box
skinny76
---------------------------------------------Originally posted by Master Fabbersounds to me like the fill and dump are both energizing at the same time. Unwire the dump valves and see if that stops it . That will tell you if that is whats happening. Good luck JR---------------------------------------------I think your right, But if I unhook the dump and hit the fill switch, Air still blows out the dump!?
Layumon22s's avatar
Layumon22s
do you have asco valves? Mine do this sometimes and I have no clue why, doesn't really bother me just sort of annoying
skinny76
---------------------------------------------Originally posted by Layumon22sdo you have asco valves? Mine do this sometimes and I have no clue why, doesn't really bother me just sort of annoying---------------------------------------------No mine are Danz.  I just dont understand because it seems like the Fill and Dump open together!!
Ron_autoloc's avatar
Ron_autoloc
What switchbox do you have?
skinny76
Fixed!! One of the wires in the valve had come undone!! Everything works fine now. Its an AVS 7 switchbox
s10
last post by baha +1y
