laying an 84 fullsize chevy
kookennay@live.com's avatar
kookennay's avatar
kookennay
what all is involved in the front. do you have to z it to lay out or is there a way around it. do i need drop spindles. and what size bags. and who makes a kit for the back like a four link or does anyone make one. i tried searching and really couldn't find anything. any help is greatly appreciated.
tlw32882's avatar
tlw32882
Edited: 7/28/2009 1:22:38 AM by DragaDodge
Edited: 7/28/2009 1:21:50 AM by DragaDodgethis is what i know.......... option 1.) zing the frame at least 1.75" to lay flat frame option 2.) zing the frame 3.5" and cutting the bottom of the frame off underneath the cab to lay pinch option 3.) using a dropmember from SD or porter to lay frame option 4.) using a dropmember from SD or porter and zing the frame 1.5" or more and cutting off the bottom of the frame to lay pinch option 5.) adding the appropriate amount to any of the above options to lay more than frame or pinch
kookennay's avatar
kookennay
so 1.75 will lay flat frame? it my buddy truck he not wanting to go to the pinch,well not yet anyway.
tuckinlugs06's avatar
tuckinlugs06
well on my 82 it lays flat frame and no z
tealchevy's avatar
tealchevy
only z'ing it 1.75 inches also allows you to keep your stock floor inside the cab and stock steering (you have to notch the upper control arm a tad) but you have to recess the cups in the lower control arms to do this.
kookennay's avatar
kookennay
so it will lay with out a z
slimneverdies
In order for the entire frame to lay,  the part thats stopping the front is the lower control arms. Thats for the C10's and I'm not sure for the dually. So either Z or dropmember.
