Ford Trucks \  lost keys to a 87 ranger
Ford Trucks Make Specific
views 489
replies 10
following 8
1lowrngr   +1y
so i lost my keys its been about a week i decided to go out and just buy a new ignition from autozone it says to take the old ignition out you need your keys is there another way to take the old one out? thanks for your help
menace   +1y
Get ghetto on it, and jam a flathead into the ign lock, the only thing thats holding it in is a little pin on the bottom side of the ignition lock, you may be able to take a real small punch and smack the pin and it may break off and let it turn so you can get it out.
airrideluvtruck   +1y
If you havent changed the ignition out yet. Remove the passenger side door lock and there should be a code on it that a locksmith can use to make you a new key. Ive had to do it a couple times, and it was cheaper and easier than replacing the locks and ignition.
bodydropped85   +1y
you have to drill the release pin out,its on the bottom of the column were the cylinder is.
ShaveDnFlamed99   +1y
call a locksmith. i did it last week for my d50 cost me $100 cause its a a Jap ignition but its easier than anything else
gimp5561   +1y
i have keys colum and lock cyc. all for 200 and it comes witha frame and an 87 extra cab body with drop beams in it..
1lowrngr   +1y
hey thanks for all your guys help i went to a lock smith yesterday and they were closed so il prolly just drill the release pin out today
aon-teach   +1y
Ahh Matt, what the hell! You didn't have a spare key? Bet you'll have one next time
stewranger   +1y
Matt, make sure you center punch that pin really good, the surrounding column is made out of paper compared to the lock pin, if you slip off bad things can happen.  If you know anyone with an older Ford, try their keys. Ford really got lazy with key patterns in the mid to late eighty's and I have seen many cars share keys.
bodydropped85   +1y
i had a key cylinder colapse in my old 92 ranger...
