quick question
quick question
chopedmazda
in the welding technique thread. you mentioned that you can stitch weld everything. so if i just turn the heat up more i can stitch weld it and it still be strong
BioMax's avatar
BioMax
If you are going to stitch weld it always a good idea to make sure that the metal is ground clean. The grey scale that is on most material makes it tough for a stitch weld to penetrate properly. Also, if you live in a cold climate, it's a good idea to pre-heat the material so that the weld can penetrate easily. With that and dialing in your welder, you can easily get away with stitch welding everything (within reason).
chopedmazda
what if i bevel the edges aswell. will that help it penetrate better
humanmachinehead's avatar
humanmachinehead
--------------------------------------------- Originally posted by yota4life what if i bevel the edges aswell. will that help it penetrate better --------------------------------------------- yes, you should do that with any thick material where penetration is key, whether you stitch or weld it in one pass
BioMax's avatar
BioMax
^^^ True
