Mini Truckin General \  What size Pipe do you run????
views 306
replies 14
following 10
02ramon20s   +1y
When custom fabing your rear air setups, what size tubing do you nomally run
tre5   +1y
Do not run pipe!!! It is not meant for structural applications.For a 4 link setup I run 1-1/4" .120 wall chromoly. It's $4.40 a foot where I get it from. I use 3/4" heims with 5/8" misalignment spacers.
time1   +1y
1.5" 1.20 wall
AVTekk   +1y
1.5" DOM no less than .120 wall and do not run pipe!
02ramon20s   +1y
im sorry i didnt mean pipe....you got me......well it sounds like 1.5, & .120 wins... Thanks guys
mindlissmetalfab   +1y
Edited: 8/5/2009 12:31:49 PM by iLLblazer
Totally dependant upon what you are building (bridge, link bar, crossmember), how loads are being applied to it and the vehicle itself.
02ramon20s   +1y
clearly im getting ripped offf,,,,or maybe not.  the metal comany i called, $11.60 per ft. on a 20ft stick $232. Is this right or what???
milenk0   +1y
around our area, that's the going rate. southern steel was my best answer, and it was around the $250 mark.
02ramon20s   +1y
aight
maz duh   +1y
---------------------------------------------Originally posted by 02ramon20sclearly im getting ripped offf,,,,or maybe not.  the metal comany i called, $11.60 per ft. on a 20ft stick $232. Is this right or what???---------------------------------------------If you are talking 1.5x.120 cold rolled electro weld(CREW) tubing then I would suggest you keep looking, that price is too steep.
