S-10 guys
minitrucka4life@yahoo.com's avatar
S-10 guys
EKSESSIVdime's avatar
EKSESSIVdime
i have a 2000 s-10 and want to install sonoma headlights, how do i go about this?? is there anyone whos done this that can give me some pointers??
layeddime's avatar
layeddime
pull your s10 lights out and put the sonoma ones in. change out the grill and bumper. easy swap.
EKSESSIVdime
sweet so i wont have a problem mounting them or nothin?? cool thanx for the feedback, its much appreciated!!!
layeddime's avatar
layeddime
no problems at all with this swap
projekt94's avatar
projekt94
dont u need to swap core supports?? i didnt and my noma lights sit crooked. now im looking for stock front end.
SoloSpecialties's avatar
SoloSpecialties
im pretty sure you need to swap core supports too
Slappy Mc Nasty's avatar
Slappy Mc Nasty
negative. i have a 2002 dime and i swapped out the headlites, bumper and grille for sonoma headlites and bumper and i have a bravada grille. everything fits like factory
projekt94's avatar
projekt94
well son of a bitch!!! wat the hell happened to mine?!?! hahahaha i have an 03 and they sit crooked
AVTekk's avatar
AVTekk
You only need to swap core supports if you are going from one styling designation to the other, ie from 94-97 to 98+ or the other way around. If you stay within your years but simply swap to a different make they will bolt on directly. Some of the older swaps will require new light pigtails as well. If your lights are crooked they are not sitting in the core support correctly, they need to be adjusted, or you have some lousy knock-off lights.
projekt94's avatar
projekt94
cool cool. ima try it out. thanx for sum input
