Chevy/GMC Trucks \  NEED HELP WITH MY S-10
views 191
replies 4
ssbkold24   +1y
99 S-10 bagged and bodydropped and all that good stuff. it's a 5 speed and i can't get it in any damn gears!!! when i turn the truck off i can go thru all the gears fine. just not when it's running! i have no clue what's up. need some help please!! thanks
specv02   +1y
Edited: 8/11/2009 11:17:28 AM by specv02
Sounds like ur clutch linkage adjustment im not sure if its cable or hydraulic but its in the clutch and something isnt right. Did u mess with the pedal or something in that area?
ETNSFLT   +1y
I know when the shop bodydropped my S-10, they had to use a clutch slave cylinder from a Toyota because the stock one was too long and the 20's hit it.  The problem is definitely a clutch thing if you can get into gear with the engine off but not when it's running. -Stew-
DougyFrisch   +1y
sounds like the clutch isn't kickin in... do you have pressure behind the clutch when you push it in? if not you'll need to bleed the clutch line...   check the master cylinder up on the firewall and make sure you got fluid, next check the slave down on the pax side of the tranny. it's that black tube that's about 6 inches long, it's got a bleeder on the top of it that you'll need a lil allen wrench to loosen...  it's a 2 man job, but get under the truck and have the allen in the bolt and in the closed position, now have your buddy in the truck pump the clutch 5 or 6 times and then hold it down, now you release that bleeder for just a split second to let the air purge... do that process a few times and see where it gets you...   if you still got pressure and it won't engage, take the slave cylinder out of the tranny (a pain in the ass btw) and make sure the shaft it pushing out when you press the pedal...
ssbkold24   +1y
thanks for the help guys. think i'm gonna start with bleeding clutch line first and then go from there.
