Ask A Pro \  C10 A-Arms???
C10 A-Arms???
Ask A Pro Q & A
views 269
replies 4
overkillFFF   +1y
Edited: 8/11/2009 6:18:08 PM by layinbody 720
Edited: 8/11/2009 6:15:55 PM by layinbody 720
Okay, so here's the deal. I have a 1985 chevy crew cab with now 1/2 front clip and rear axle. The frame is new front to back with 3 X 4 X 3/16 tube, except for the portion going up to the xmember which is 3 X 4 so I could get the proper miter cut, and in doing so, I raised the whole front xmember up 2". My qusetion is now when I air my truck all the way up with my re7's, the furthest outside part of the upper a-arms now touch the spindles, which are drop spindles. I'm having trouble getting enough lift to turn my tires because I also cut 3 1/4" of the rockers and kept 1/2" What is the best, most economical way to keep my upper arms from touching my spindle? I'm a journeyman welder/fabricator, so altering the arms doesn't scare me, but I'd like to avoid getting tubulars just because of the shear cost of them.
2_Footaz   +1y
on my factory ones i had to cut away the part of the upper arms that hit the spindle.  but now im just building my own uppers and lowers.
overkillFFF   +1y
Anyone else have any advise? There are enough c10's out there that someone must know some way to make the stock arms work!
BioMax   +1y
build your own arms.
stlowburban   +1y
Edited: 8/21/2009 10:30:20 PM by STLowburban
I just did a 81 thats lays on 24's..  I Z'd it 3 1/2" w 3" spindles.  It lays no prob and lifts over the 24's without binding on stock arms and ball joints so I don't have any help for you but if you check on C10forum.com Jake ( Phat Phabrikationz)  has done a bunch on big wheels and can prolly help you out.
