Mazda Trucks \  94 mazda wiring
94 mazda wiring
Mazda Trucks Make Specific
views 256
replies 3
dkleeman89   +1y
Does anyone know what color the ignition wire is on a 94 b3000 v6. I am trying to wire my power for the compressors through it but dont know what wire it is!! any help would help thanks
fredstinting   +1y
1994 Mazda B-Series Alarm, Remote Starter, Keyless Entry Wiring InformationConstant 12V+Yellow Ignition Switch Harness StarterRed/Light Blue Ignition Switch Harness IgnitionRed/Light Green Ignition Switch Harness AccessoryGray/Yellow Ignition Switch Harness TachTan/Yellow Coil Brake SwitchGreen Brake Switch Trunk Pinn/a  Parking LightsBrown Light Switch Hood Pinn/a  Factory Disarmn/a  Door TriggerBlack/Light Blue (+) Driver's Kick Panel Door LockPink/Yellow Driver's Kick Panel Door UnlockPink/Green Reverse
fredstinting   +1y
1994 Mazda B-Series Cruise Control Wiring InformationConstant 12V+Yellow Ignition Switch Harness or Use Hot Side of BrakeSwitched 12V+Red/Light Green Ignition Switch Harness GroundUse Chassis Near Cruise Control Module Hot Side of Braken/a Brake Switch Cold Side of BrakeGreen Brake Switch TachTan/Yellow Coil VSS WireGray/Black Driver's Shock Tower Harness from Transmission Pulses Per Mile8000 PPM Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
fredstinting   +1y
1994 Mazda B-Series Stereo WiringConstant 12V+Green/Yellow Switched 12V+Yellow/Black GroundChassis IlluminationBlue/Red Dimmern/a AntennaRight Front Front Speakers5" x 7" DoorsLeft Front (+)Orange/Green Left Front (-)Black/White Right Front (+)White/Green Right Front (-)Black/White Rear Speakers5" x 7" Rear CornersLeft Rear (+)Pink/Green Left Rear (-)Pink/Blue Right Rear (+)Pink/Blue Right Rear (-)Green/Orange
