Air Ride Suspensions \  Need some ideas and some help (colorado front)
Air Ride Suspensions Q & A
views 197
replies 1
following 2
azzbustin30th   +1y
ok i just picked up a 05 colorado that is already bagged and the front is about 1/4 inch from laying on the driver side and about 3/8 on the passenger side. ive searched and searched about the control arms but every place that is listed the web address no longer works or they dont have anything that would help.
---i read seths pie cut sticky would this be a solution along with putting the ball joint on the top of the upper?
---would DJM 3" lowers do the trick?
any help is more than greatly appreciated.
teckn9ne   +1y
Check out 355nation.net lot of helpful people on there, rado ball joints are cast at a bad angle, im sure you could pie cut your arms to get it to lay out,  Lower control arms probably wont be the answer, How big of wheels are they? Also double check and make sure its your ball joints holding you up and not your bags...
