Bottom fender mounts on B/D yotas...
sheffieldced@gmail.com's avatar
Tacon19s's avatar
Tacon19s
So I have drug off the heads of my fender bolts that mount under the front of the rockers on my Taco. Id like to see some solutions to this issue. For you guys with bodied toyotas or any trucks that have under the rocker fender mounts...how have you fixed this?
tuckinlugs06's avatar
tuckinlugs06
well not a taco but mine is close to being gone ...and what i plan to do is make a tab on the inside of the wheel opeings at the bottom to bolt it to..i have also seen some poeple weld a plate on the inside of the fender and make it big so when its layed out you cant see the top so it looks clean behind the wheels and smooth...and just bolt it to somewhere on the inside
