Body work and Paint \  Prepping diamond plate?
Body work and Paint Q & A
views 974
replies 4
draggindakota   +1y
I want to paint my dp tool box on my daily black. It's oxidized pretty bad though. Should I polish it out first, then scuff it, prime, paint ect. or can I just acid wash it and go from there?
dragggn   +1y
is it alum?if so, scotchbright it with "Aluminum Prep" (dupont)  its an acid wash that will give it enough tooth to prime/paint as usual.  the scotch bright is just to help the process work a little faster, and to hekp knowck off any bigger chunks of goo/tree sap/ or what ever..
draggindakota   +1y
Thanks, I'll try the aluminum prep. Any Idea where I can buy it?
seanb   +1y
You might wanna' try an epoxy primer over that. Any auto paint supply can get you what you need.
sik_kreations   +1y
sand it with whatever the paint manufactures recommendation. etch primer and seal and paint.  aluminum likes an etch to it, whether it be an etch primer or a aluma prep.
