Toyota Trucks \  4runner front end swap on my 94
Toyota Trucks Make Specific
views 2310
replies 7
following 6
wsm1986   +1y
I have a 94 Toyota pickup 2wd that i wrecked a couple weeks ago. Not bad just needs front bumper grill hood and passenger fender. I want to do the 4 runner front end. I found one with a bad engine and the body is in real good shape.It is a 93 4wd 4runer.  Will the front end off the 4runner bolt right up to my pickup. Are any mods needed to the radiator support? Thanks for any help.
tuckinlugs06   +1y
yes it will bolt up
tntmaz   +1y
the headlights and the grill bolt into different locations on a 4runner vs. pickup....weld the 4 runner support on if you are buying the whole front
biggin   +1y
you might have to make a few of the tab holes bigger for the grill and drill a few new holes for the sides of the headlights to bolt onto the core support but no need to swap the core support itself.
FbiMike   +1y
Hey Will, These guys are correct.  They will bolt on but you will have to modify the mounts a little bit to make it work.  Thanks, Mike
smctoy   +1y
youll also need to make the holes where the headlights go alittle bigger too & make sure you get the rear pigtails off the headlights cause they are different & if you running the whole bumper then get the rear pigtails/lights off the bumper lights too cause they are different as well!
wsm1986   +1y
thanks guys for the help. the 4 runner i was after sold before i could get but im gonna keep looking. again thanks for the help
wsm1986   +1y
  i found another one pretty quick. no engine in it. body seems to be in good shape. gonna go check it out tommorrow after work. This one is alot cheaper too!!
