Ford Trucks \  front suspension problem
Ford Trucks Make Specific
views 289
replies 2
following 2
bagged98f150   +1y
 i have my front end bagged on a 98 f150 with cups on top and have djm control amrs with plate welded on top of arms to bolt bags straight to them and i have fliped the bottom ball joint to raise stock spindle up 2inch. but when i lay out im about a inch off the ground on the pass. side but on the ground on the right side. im measureing off the frame under the cab. and when i lift up my driver side is around 1 to 2 inch differnet from the wheel to fender from the/pass. side. and the driver side where u bolt the bottom control arms up the holes are sloted but the pass side in not sloted y is that also
Layumon22s   +1y
could you upload some pictures of your suspension? I've read your post 3 times and still can't figure out what is going on.   what is slotted the upper or lower control arms?
bagged98f150   +1y
sry the sloted part im talkin about is where u bolt the lower control arm to the frame. its sloed where you can put in closer to the engine or away from it and ill try to get pics later tonite
