pinstripping brush care???
mazberry-delight@shaw.ca's avatar
mazberrydelight's avatar
mazberrydelight
ive had a set of pinstripping brushes for a couple years now , but have never had time to try them out . i bought a few cans of One shot today and am  hoping to mess around a bit this weekend , my questions are 1 what should i use to clean the brushes, and 2 should i put anything on the brushes to keep them soft and pliable after ive cleaned them / thanks
slammedcivicsi's avatar
slammedcivicsi
you are supposed to keep them in oil.
builtbybyc
kerosene, linseed oil etc laying down
DougyFrisch's avatar
DougyFrisch
i clean my brushes with lacquer thinner or mineral spirits and then give them a generous portion of Neatsfoot Oil and then shape them before i place them flat in my padded box. the oil will keep the brushes soft and in the desired shape so they don't get a bent and fucked up... just before you go to paint again make sure you clean em out real good...
dragwindsor's avatar
dragwindsor
It also helps if you pull em out once and a while.  They WILL get krispy if let alone for long periods.
mazberrydelight
thanks guys
DougyFrisch
--------------------------------------------- Originally posted by dragwindsor It also helps if you pull em out once and a while.  They WILL get krispy if let alone for long periods. --------------------------------------------- Yes they will, but as long as you got a generous portion of oil on them they will stay good for quite a while. they will still hold their shape even if they start to stiffin up a lil, and as soon as you clean that oil off they will be as soft as new...
