Air Ride Suspensions \  custom made control arms
Air Ride Suspensions Q & A
views 659
replies 7
nofnaround   +1y
Im about to start building my front clip. It will have custom made spindles and control arms and lay on 22s. My question is are uniballs my best choice or poly performance ball joints?
TwistedMinis   +1y
Poly Performance doesn't make ball joints. They sell Uniballs and a similar pivot joint however. If you want to use ball joins look into Howe Precision. Aside from that you can't beat the precision of a uniball, and a uniball is more affordable than a Balljoint and a press in or screw in sleeve from Howe.
toreadorxlt   +1y
Edited: 11/9/2009 7:54:39 PM by toreadorxlt
seth do you have a link to these howe screw in type uniballs?.edit - i realized you were talking about howe balljoints, nevermind
nofnaround   +1y
sorry seth i ment power performance.
nofnaround   +1y
is poly performance the best pace to get uniballs? poly performance are  $100 each arn't they?
TwistedMinis   +1y
Okay I see, that makes more sense now. I probably should have put that together since I just installed some Power Performance steering parts on an S10. I'm not sure on PP price on Uniballs. I actually get mine from a few different places, depending on what I need. For someone buying retail Ballistic Fabrication is probably a good bet. I think a 1" uniball with misalignments and a steel cup goes for less than $75.
selfbuiltrods   +1y
$57 from ballistic. best investment ever.
nofnaround   +1y
Just ordered everything for control arms and spindles. I used Ballistic for the uniballs thanks guys.
