Body work and Paint \  Just a question that popped in my head.
Body work and Paint Q & A
views 730
replies 11
following 10
myfirstGMC   +1y
Does anyone use any type of file instead of a grinder to knock down welds on body work to prevent warping? Was just wondering if it could be done and what type of file would you need to use.
laynwindows   +1y
its the welding that warps shit. not the grinding. and i use a sanding disk, (not flap disk) and very rarely use a grinding wheel, cause i personally think they suck
myfirstGMC   +1y
Edited: 11/13/2009 4:08:55 PM by myfirstGMC
OK, thanks. Yeah I know if you're not careful with welding you can really mess up stuff, but I've heard you can do just as much damage staying in one spot too long with a grinder, even with a flap wheel. I'll just be really careful with the flap wheel then.
smithchassis   +1y
---------------------------------------------Originally posted by laynwindowsits the welding that warps shit. not the grinding. and i use a sanding disk, (not flap disk) and very rarely use a grinding wheel, cause i personally think they suck---------------------------------------------couldnt be further from the truth, a grinder, even a flap disc will warp a panel beyond belief. we use a green 3m stone to knock the weld down then proceed to a flap disc.
astromanwes   +1y
Yeah, grinding can warp it too.  I use a cut off wheel on it's edge.  It works really good and creates hardly any heat.
spider97   +1y
---------------------------------------------Originally posted by laynwindowsits the welding that warps shit. not the grinding. and i use a sanding disk, (not flap disk) and very rarely use a grinding wheel, cause i personally think they suck--------------------------------------------- x2 i love my high speed sander and either some 40 or 60 grit
4DOORWHORE   +1y
what r u welding
90yota   +1y
---------------------------------------------Originally posted by astromanwesYeah, grinding can warp it too.  I use a cut off wheel on it's edge.  It works really good and creates hardly any heat.---------------------------------------------thats the way I did  it for years when I used to do bodywork for a living...works well and you're able to keep the grinded area to a minimum
myfirstGMC   +1y
---------------------------------------------Originally posted by DAILYDRAGGERSPRESwhat r u welding--------------------------------------------- Roll pan and tailgate.
laynwindows   +1y
---------------------------------------------Originally posted by smithchassis---------------------------------------------Originally posted by laynwindowsits the welding that warps shit. not the grinding. and i use a sanding disk, (not flap disk) and very rarely use a grinding wheel, cause i personally think they suck---------------------------------------------couldnt be further from the truth, a grinder, even a flap disc will warp a panel beyond belief. we use a green 3m stone to knock the weld down then proceed to a flap disc.---------------------------------------------you're not supposed to go crazy with the grinder. you're supposed to do a little at a time and allow time to cool down. same with the welding, its time consuming but your shit will be straight
