Tools \  No penetration.......
Tools Q & A
views 1133
replies 10
following 10
CLNSHAVN   +1y
Just looking for a little help here.  I have a hobart handler 140 and i just set it up and started welding my 3/16" front brackets(im using gas by the way), but it doesnt seem to be penetrating.  If anyone knows why or has any suggestions on what to do would help me out a lot.
bill brasky   +1y
turn it up
CLNSHAVN   +1y
its already all the way up
supravan   +1y
did you 45 the edges of the 3/16th?
insaneautoconcepts   +1y
check your wire speed
nvr2lotaco   +1y
swap your positive and negative wires inside the welder above the rollers for the wire. Your polarity is oppisite of what it needs to be....hope this helps bro
FADE2BLK94   +1y
...and dont forget to go sloooow when welding thick plate and using a smaller welder
mississippirob   +1y
It's all about the angle of your dangle..
toffeechips   +1y
No matter what i never get penetration
bill brasky   +1y
---------------------------------------------Originally posted by toffeechipsNo matter what i never get penetration --------------------------------------------- need to run your wire out a lil more so you can break the plane
