Toyota Trucks \  90 toyota clutch
90 toyota clutch
Toyota Trucks Make Specific
views 224
replies 5
following 5
2be1off   +1y
I have a 90 toyota pickup 22re and i was wondering if the clutch master cylinder has to be higher or at the same highth as the slave cylinder??? or can i put it lower then the slave cylinder?? thank you
bodydropped85   +1y
definatly higher.
94toy   +1y
Ok dumb question I thought they were the same thing, whats the difference?
90yota   +1y
---------------------------------------------Originally posted by fezOk dumb question I thought they were the same thing, whats the difference?---------------------------------------------the clutch master cylinder is attatched to your pedal and forces the fluid through the line down to your slave cylinder, which is mounted on the outside of the tranny
2be1off   +1y
so is there any reason why your not able to doit lower??? i dont understand. does it bleed back or something???
getNlaid621   +1y
i dont see why it would have to be higher. on some hot rods they have floor mounted pedal assemblies where the master is below the floor. im not positive but i think on these applications the master is lower than the slave cylinder. hope this helps
