Mini Truckin General \  Motor mounts...
Motor mounts...
views 162
replies 3
lyinlow   +1y
Just curious if anyones used a 4 link bushing for a motor mount? If so did you encounter any problems? Or do they hold up fine? I am thinking they should be ok since in a control arm they are bearing alot mor weight than just a motor.
bodydropped85   +1y
yea they will be fine, a lil stiffer, but fine.
TwistedMinis   +1y
Strength isn't the issue, is vibration dampening. It will amplify any vibrations your motor has. I would stick with rubber if you can, but I realize it can be a space issue. So, whatever you end up using, put the same thing on the transmission mount.
bodydropped85   +1y
yea thats what i meant to lol.
