Air Ride Suspensions \  Smc valves
Smc valves
Air Ride Suspensions Q & A
views 253
replies 7
following 5
1twztdwagon   +1y
My wifes ride has been bagged for bout 3 years now yesterday we drove the car no problems go to take off today an the fill valve for the back doesnt click or anything you click it to dump it works front works compressor turns on i thought the switch was bad so we went an bought a new switch same thing she has a fill an a dump for the front an a fill an dump for rear how can i trouble shoot if the valve is bad?
Spin_155   +1y
take it off and hook it straight to a 12v battery it will open if its good.
1twztdwagon   +1y
how do you know if it opens or not it clicks now if you try to dump it but no click to raise it up normally you can hear it click
Spin_155   +1y
you have a fill valve and a dump valve it sounds like your fill valve is not working but your dump valve is find the fill valve and test it
1twztdwagon   +1y
i know where the fill valve is how do you test it is what im asking.. hooking the valve up to a 12 volt batt straight isnt going to tell me if its filling or dumping
GetLow   +1y
you should be able to hear it click if it's opening
Spin_155   +1y
the solenoid will click and open if your valve is working. if you have the valve in your hand you will hear and feel it opening and closing when you touch the wires to a battery.
1twztdwagon   +1y
no click does this mean the valve finally went out?
