help my tahoe wont start
nevrr2lo@yahoo.com's avatar
nevrr2lo's avatar
nevrr2lo
I have a 99 tahoe i just replaced the cap, rotor, plugs, wires,fule pump,ign control modual, and coil pack. It gets spark and gas but still wont start im at my ends rope with this any advice sugestions please help.
slmmdd97's avatar
slmmdd97
dont see it on the list but did u check or replace the fuel filter, clogged fuel filter are big thing.  I had a 97 xcab and changed the fuel filter and fuel pump cause of the wining noise and it seemed to help run better hope this helps
nevrr2lo's avatar
nevrr2lo
thanks ill try a fule filter but like i said it is getting gas it just turns over and dosnt even try to start
slammedrt
Are you sure that you hooked up the spark plug wires in order? If not its not going to start. I would check that and make sure that the firing order is also right.
firefighter5325's avatar
firefighter5325
yea if your getting spark and gas you should get fire even if its not good fire it should still fire something isnt right
nevrr2lo's avatar
nevrr2lo
ok i checked the fireing order replaced the fule filter and still no dice wtf mabey it just needs a stick of dynomite
pearldrop's avatar
pearldrop
I just spend two weeks tryng to figure out what was wrong with my Suburban and it was the fuel filter. I totally thought it was something ignition related so I replaced a bunch of stuff up there first.   Make sure you check the fuel pressure. It should be over 60 psi when you turn on the key and it shouldn't bleed off right away.Do you have any check engine lights?
nevrr2lo's avatar
nevrr2lo
ok will do first thing thanks its weird i drove it shut it off went out the next morning and nothing
