Air Ride Suspensions \  What is the best digital gauges for the money?
Air Ride Suspensions Q & A
views 316
replies 5
FCKNLOW   +1y
What is the best digital gauges for the money?  I'm looking for a 5 gauge set up.  I've looked at AVS and Dakota.
Thanks for any help in advance!
Layumon22s   +1y
I've had a set of Dakota's since '03 and they are just now starting to give me an issue but it's my fault. My old setup didn't have a water trap so it fouled out one of the sensors and it won't display a pressure below 50 PSI, not really an issue with a full size since it takes me close to 100 psi to get enough lift to drive. I can buy the replacement sender and fix it but I'm just too lazy...
pdolgner   +1y
I had a Dakota also.  It worked fine but I wanted it to match my truck so I ordered one from AVS.  That being said I like the AVS one better.  Comes with three different trim plates, can be switched a bunch of different colors and is all plug and play.  I am not sure but I think you have to pay more also to get the higher psi with the Dakota?  Either way I like it a lot more than my old gauges.....
FCKNLOW   +1y
I really like the AVS ones.   they are alot cheap compared to getting the same thing in a Dakota.
jumbo   +1y
i don't know how well they work, but i really like the look of these in blue: http://www.cyberdynegauges.net/
FCKNLOW   +1y
look good but they only go to 150 psi.
