Air Ride Suspensions \  Shock Mounthing Length Sheets
Air Ride Suspensions Q & A
views 359
replies 5
following 5
slammedcivicsi   +1y
Is there another site, other than the Monroe website, that lists shock mounting lengths ? I am searching for something in the 10.75" collapsed 18" extended. Give or take, with Loop/Loop ends. I only seem to be able to find stud end shocks with similar dimensions. -ThanksBrad
maz duh   +1y
Stock 84-95 toyota pickup shocks are 12" compressed and 20" extended which is pretty close to what you are looking for and they have eye/eye mounting. Might be worth looking into if you can fit the extra shock length. I have an old Monroe catalouge I use for the specs, it has been the best resource I have found.
mindlissmetalfab   +1y
Monroe 31000  12 comp 19.5 extendedMonroe 32207  11.25 Comp  17.875 extended I cant find anything else with that much stroke at 10.75" collapsed.
guiltybydesign   +1y
If you talk real pretty the guys at autozone/oreilieys will give you last years shock book. They usually keep them.
badcoma   +1y
rancho also has one on there wed site you can download in pdf
slammedcivicsi   +1y
thanks for your help everyone, I have some strict fitment issues right now, and roughly 10.5"-11" collapsed is kinda my max, I dont want to be fully collapsed and have pressure on the mounts, and I would just like to get a little more lift than what I have now.  I may need to perhaps re-design my shock mounts, as they are somewhat restrictive to the design of the rest of the suspention.
