Toyota Trucks \  what can the stock yota rear end handle
Toyota Trucks Make Specific
views 349
replies 7
following 6
tuckinlugs06   +1y
anyone know what the max hrs power the stock 89-94 yota rear end can handle and is there a kit to build it ...and also what rear end can fit without narrowing thanks please
92zuzuman   +1y
i have an 89 yota 2wd with a chevy 305 and powerglide trans and beat on the stock yota rear for months drivin it daily. I still have the truck and the rearend is still holdin up. I believe they are 4.10 or something like that so u can take off nice with it.  If you go with a ford 9" ur gonna have to get it narrowed. Check out ford rangers might fit some of em came posi with the same lug patern. Or check out jeep wranglers with lockers and fancier cherokees have rear disc brakes all with your lug pattern.
tuckinlugs06   +1y
well this small block isnt goona stay stock so i know im gonna blow the rear...i plan on puting a explorer rear end cause they came with rear disc...i just wanted to know how long this onewould last...i plan to take it to the track next to my house and would like to beef it up but cant find anything to do so
cookiemonster13   +1y
there are lockers and gear sets available for the toyota rearends and moser can make any strength axles you want. you just need to look through some 4X4 sites to find supplies. when i built my last yota rearend i found a company that had gear sets from the 2's area up into the high 5's. these rearends are used alot in round track racing and 4x4's. they are not cheap to build though! if you want more info just google toyota gear sets and you will get info http://home.4x4wire.com/erik/diffs/
tuckinlugs06   +1y
4x4 us the 6 lugs axles and yes they make upgrades for the 6 lugs but that wont help me...it would be cheaper to swap in an axle then have some custom shafts made...i have a mazda irs but im sure it wont take anymore then the yota axles
cookiemonster13   +1y
they make the same upgrades for the 5 lug! yes it would also be cheaper to swap it out. a 9" built and narrowed will be cheaperd. the last ring and pinion i bought for a 8" yota rearend was almost $700 just for the ring and pinion. not counting all the bearings and crush sleeves and such!
orangemazdab2000   +1y
What about a late model Mustang 8.8 with factory posi? I believe the '94 and up rearends are 5 lug. I'm not sure how wide they are though...
