Page 1 of 10
Build-Ups \  2007 Acura TL, hydroholics install
Build-Ups General Discussions
views 3359
replies 92
following 47
tre5   +1y
This car was dropped off Monday and I finally got some time to really work on it. The owner is Ricky and he drove it out from New Mexico. I did some little stuff on Tuesday, but most of these pics are what I got done today. It is getting a 2 pump, 6 dump Hydroholics setup with 4 accumulators. It is also getting 3 Kinetik HC1800 batteries. 8" cylinders in the front with the hydroholics cups bolted into the factory wishbone. In the rear it is getting 10" cylinders with 2-1/2" extensions and heim joints. I planned out the pump mount yesterday, had it water jetted, picked it up today and welded it up. I cut out the tops of the strut tower to allow the control arms to come through. If anyone else ever has to do one of these, check out how much of the interior I had to pull out to get to the rear struts.
JustRob   +1y
Damn! Cant wait to see how this one comes out, my mom drives one of these and i have always dreamed about this lol
juicedwagon   +1y
so far so good, cant wait to see what it looks like done
slammed89s10   +1y
nice work man....i love your build up threads because they always have a ton of pics
soccorjimmy   +1y
I love reading your new builds, everything is done so clean. Makes me want to go to dros. Keep up the great work. JIMMY
DRGN4DR   +1y
reminds me of my accord. thats about how much i had to take out of the interior of my accord just to unbolt the struts...PITA
fatbastardcustoms   +1y
looks good cant wait to see it laid out where did you get the stuff that went around the hole for the upper control arm and what is it called. i need some in the future..cant wait to get my civic on the ground here soon.
hey have a question on your cylinders are you guys running triple seals, quad seals, poly packs or something im unfamiliar with cause i know the accums kinda use the cylinder as a shock then. so more or less just curious cause i hate having to replace the seals
tuckinlugs06   +1y
hey man can you post as many pics that you can on the rear cause this is the same way i have to do my girl eclipse the rear has to be done witht he heim also
cookiemonster13   +1y
---------------------------------------------Originally posted by fatbastardcustomslooks good cant wait to see it laid out where did you get the stuff that went around the hole for the upper control arm and what is it called. i need some in the future..cant wait to get my civic on the ground here soon.---------------------------------------------that is called pinch welt, you can buy it at most paint and body shops by the foot.
