what should i pay for it
draggin04@aol.com's avatar
draggin04's avatar
draggin04
1973 vw super beetle the interior has been comepletely redone two rust spot on the back by the back window and some surface rust runs and drive
firefighter5325's avatar
firefighter5325
one of my buddies i work with is a VW guru i will ask him about it. only thing I know with giving an estimate on those is you need alot of details on the condition and all that stuff
draggin04's avatar
draggin04
thanks let me know what you need to give a good estimate and i will get it i just dont wanna pay to much for it
leydbck's avatar
leydbck
Edited: 1/3/2010 12:42:00 PM by leydbck
Edited: 1/3/2010 12:36:39 PM by leydbckthings to keep in mind. Super Beetles use Mac struts up front and IRS in the rear. If you plan on lowering it 73 is the newest you want. in 74 they made some changes to the front suspension and it takes a bit more work to get it lower than 2-3 inches out of the front. Supers tend to have a shimmy/shake issue with the front. Plan on replacing just about EVERYTHING up there. Struts, bushings, tie rod ends... maybe even the steering box. The shimmy issues happens at certain speeds, each is different. Mine is between 43-47 mph, some are a lot worse. The front end starts shaking and causes the wheel to start shaking. That is something i would look at if you are able to test drive it.  If it has a few rust spots it has more. Look at the floor and the heater channels. Maybe even the front area of the pan too. Without pics it is hard to estimate a price. I paid $1500 for my 74 and it was in great shape. From what I have been told by some VW people ours was worth around $2500-$3000. I have seen restored Supers go for $6000.  Mine had no rust. Kind of ran, and the interior has some flaws.
