Ford Trucks \  twin i beam question.
Ford Trucks Make Specific
views 287
replies 3
homebuilt   +1y
can i take the i beams out of lets say a 73 f-350, cut them, and weld them together to make a "rat rod" straight axle?  of course with gussets.  any info would be great.  thanks.
boooghar   +1y
can you - yea, should for the sake of humanity - NO. try this  http://www.speedwaymotors.com/Semi-Elliptical-Straight-Axle-Front-End-Kits-Chevy-Spindle,8982.html
homebuilt   +1y
just askin.  looked at your 49 and you said your runnin dually suspension.  me too.  i need to update my pics cause it looks alot different now.  i guess im buildin a "rig rod".  well thanks for the info.
boooghar   +1y
the i-beams are forged pieces, plus i believe they go into a taper where they bolt to the frame (i may be wrong there, its been a while) you would be alot happier and healthier by buying an aftermarket kit if you want to run a straight axle
