what size tank with a york
slow50
you guys that are running yorks what size tanks do you use?
Slappy Mc Nasty's avatar
Slappy Mc Nasty
ive ran 1. a 210 with three 5 gallons2. a 210 with a 10 gallon3. a 210 with two 5 gallonsalso have set up a 210 with four 5 gallons.they pump rediculous air so almost any set-up would be fine
thacru78's avatar
thacru78
I currently have a 210 on 11 gallons...which is plenty of air for me. It pumps from 165 to 200 in about 20 seconds at cruising speed and about 40 seconds at idle. I'm fixin to add 9 gallons when I break it down for paint. Can never have enough air if you ask me.
onelow96cs's avatar
onelow96cs
york 209 with 5 gallons. on a s10. Im not a switch hitter so 5 gallons gives me a couple lifts. and more than enough time to fill between corner turns.
astrowoody75
now im not sure about this so i may be wrong... but with an EDC cant you just run a 3gal. tank? since the EDC keeps air pumpin when the engine is on? SO why would you need so much storage?
onelow96cs's avatar
onelow96cs
Sounds like your saying they are constantly running and they are not. EDC are hooked up to a toggle or pressure switch like electrics.
