97 03 f150 brake booster ???
iamgodakajebus@aol.com's avatar
tharealjoedirt's avatar
tharealjoedirt
Edited: 1/17/2010 11:01:46 PM by tharealjoedirt
heard some people run explorer ones.anyone use stock one on 22s????im rnning a ektensive set up and plan on switching my uppers left to right right to left...bout lay mine so any help suggestions ideas F150
low99maz's avatar
low99maz
what truck f-150,rangers,?????b more descriptive
N
NaviGangsta
If you raised the uppers, then switched left and right ...then the stock booster will work with a 265/35/22 unless you have an oddball offset The fuse block on driver side will have to be pushed into the cab, then the hole there sealed up. Push the wires all the way to the top and make a filler panel for the bottom part. The computer on passenger side needs moved up or shoved inside cab more and done the same as the fuse block. It's pretty easy really Main thing is to make real sure the bag doesnt rub in front. it's a tight fit against the frame.
tharealjoedirt
Edited: 1/18/2010 9:26:38 PM by tharealjoedirt
running a 285 35 22...........im also using a whole ektensive front set up then flipping the uppers...well see
N
NaviGangsta
285 is quite a bit wider really .... good luck
