does anyone know if there is a way to do a remote start on a carbureted vehicle????
ChetDyal@aol.com's avatar
DOWNHERE's avatar
DOWNHERE
And if so, is there a module that i need or a certain way of doing this????
2damlo
yes i have it on my 86 toyota  u just need to hook up the tach wire so it knows when the truck is running
DOWNHERE's avatar
DOWNHERE
yea, the tach just detects that the engine is started so it stops cranking... with a carb engine, you usually have to pump the gas to get it going...  so doesnt it crank for a long time whiles remote starting? cant that kill ur starter?
Orange Smoothie's avatar
Orange Smoothie
---------------------------------------------Originally posted by DOWNHEREyea, the tach just detects that the engine is started so it stops cranking... with a carb engine, you usually have to pump the gas to get it going...  so doesnt it crank for a long time whiles remote starting? cant that kill ur starter?--------------------------------------------- could you put a door popper on a pulse on the throttle to operate on the same signal as the starter and it would quit once it quits cranking? dumb idea?
firefighter5325's avatar
firefighter5325
If your having to pump the gas pedal then something isnt right with the carb/fuel pump.  I had a carbed small block in my dime, Before i went to an electric pump get in and turn the key and after maybe 2 revolutions it was running. now the electric fuel pump was diffrent had to prime the pump then shut the pump off crnk it turn the pump back on.
pdolgner's avatar
pdolgner
We installed them on carbureted cars when I worked at Car Toys.  We would use a solenoid/actuator on the gas throttle cable with a pulse timer and set the alarm to crank a second or two longer. Most cases it didnt work very well and would have to be adjusted once or twice a year depending on the weather, but we had cold winters up there....
Marcos_65's avatar
Marcos_65
Something is wrong with your carb if you have to pump the gas to get it going.  My 79 El Camino had that problem, a simple rebuild with new floats and it started right up.
jsutton's avatar
jsutton
I have remote start on my carbed 77 F100. I don't have any kind of actuator or anything on my throttle to pump it so it won't start it if it has been sitting for a few days. But if I drive it to the store or whatever then come back out it starts everytime. I got mine from summit. I can't remember the brand off the top of my head, been a couple of years, but it's basically the same as the bulldog brand remote start.
