Setting up front suspension with bags for drop spindles without having drop spindles available.
kaoss84@yahoo.com's avatar
kaoss's avatar
kaoss
I can't get my head around this. I am working on a '92 Toyota front clip, and I have the torsion brackets and bags, but no drop spindles at the moment. I know that I am going to need some drop spindles to correct the camber issues, but what would I need to consider setting up the bag placement without having drop spindles? Do I simply place the front clip 2" off the ground and set everything up? This is giving me a serious face ache.
kaoss's avatar
kaoss
TTT
tuckinlugs06's avatar
tuckinlugs06
what size rims does it have and what size do you plan to run?
kaoss's avatar
kaoss
Planning on running 18's on the truck. Keep in mind that this is not for a 1992 toyota pickup, I'm just using the front clip.
maz duh's avatar
maz duh
If they are a 2 inch drop spindle the method you have described should work fine till you get the cash for drop spindles, I've done it that way in the past myself.
s10
last post by baha +1y
