Valve sticking
Valve sticking
92Pup avatar
92Pup
well my valve was sticking open so i switched it with a new one and it does the same thing. anyone know why?
automatik23 avatar
automatik23
somethin is up with the switch
Layumon22s avatar
Layumon22s
Yep, I would check your switch and wiring. Make sure you have a good ground. I would switch the wiring with a different switch and see if it still happens. chances are it will work fine. In that case just replace your switch and you will be fine
DOWNHERE avatar
DOWNHERE
Could be the wiring... or if you feel it is sticking on open bc when you lift it drops right away or when you lift it doesnt move bc it releases air, it may be the direction of the valve.  It would have an arrow on which way the air should flow through, or say in on 1 side and out on the other.
