balljoint q's
gbcinvisalia@yahoo.com's avatar
balljoint q's
ford04focus's avatar
ford04focus
im gonna make my self a set of custom upper and lowers and i was curious if anyone knew which screw in balljoints would would work for a 93 pupdhp says replaemnt balljonts for his arms can be bought on hot rod websites so im guessing they are probally a s10 joint but id love to confirm that before i spend the money  thanks
maz duh's avatar
maz duh
Most likely they use a K772 screw in balljoint if you can buy replacements from hot rod stores. That balljoint is found used in the ever popular mustang 2 front suspension setup that a lot of rods run. Order one up from your local auto parts supplier and check the fit in your spindle to see.
ford04focus
yea i searched around only found a couple screw in balljoints offered anywhere and they seem to be made to fit most 60-80s chrsylerswhich your right is the same balljoints used in the mustang 2 kits so its gotta be the same joint cuz i doubt dhp is special enough to get custom joints made just for themselves
Related Discussions in Isuzu
