Pinion angles for two piece driveshaft
E
BLACKFULLSIZE
I would like to know what the pinion angles are on the front shaft in relationship to the transmission and angle on the differential.  Also,  I would need to know how much you would need to bring the carrier baring up for a 5-7" drop.  I am putting a two piece drive shaft in a standard cab pick up formally had a one piece.  I am just looking for the pinion angles on the different applications for baseline.  I am thinking that the front drive shaft is straight in line from the transmission, with the transmission at -3 degrees and the differential is at 3 degrees.  Any information would be greatly appreciated.
BLACKFULLSIZE
Is there a better place on this forum to post this question to get an answer?
Flapdisk's avatar
Flapdisk
Yea like you said.. I think the front piece is pretty much straight from the tranny to the carrier bearing then the rear piece has the angle to it..
bodydropped85's avatar
bodydropped85
search in the suspension forum, i know this has ben covered before.
