puttin 88-98 HD control arms on a 93 half ton burban
jpacker72@gmail.com's avatar
FluffyFreak's avatar
FluffyFreak
i gotta set of 3/4 ton C-arms to clean up the looks of my burban, need some tips on putting them on my truck! thanks in advance
FluffyFreak
also, what about the ball joints, can i just get the HD ball joints or do i need 1/2 tons?
groundscr8pr
you need 1/2 ton ball joints. you will also need to weld up and redrill 2 of the mounting hole in the arm.
FluffyFreak
the balljoint mounting holes?
4DOORWHORE's avatar
4DOORWHORE
or u can get a ball joint reamer drill bit and ream ur 1500 spindles for 2500/3500 ball joints
FluffyFreak
where in the world could i find that?
groundscr8pr
---------------------------------------------Originally posted by DAILYDRAGGERSPRESor u can get a ball joint reamer drill bit and ream ur 1500 spindles for 2500/3500 ball joints--------------------------------------------- you dont want to do this. there is angle built into the 3500 bj that will make them bind way before your truck lays out. you will need 1500 bj and you will need to weld up a redrill the two back holes on the arms so the 1500 bj mounting holes line up.
